On my side by side refrigerator both doors rub against the top hinge plate when opening. Since this model does not have the 7/16" bolt for adjustments how do I lower the doors so they won't rub on the hinges?
Since the unit is less than a year I would call Frigidaire and see if there is an update to the unit for this problem.
It does not look like you can adjust the doors downward. A possible fix would be to make a shim and place it under the upper hinge to add some clearance. |
THIS FORUM IS DEAD!!!!!!! |
