mindyy07@sbcglobal.net
#1 Posted : Sunday, August 25, 2013 8:24:24 AM(UTC)
I am trying to replace the gas valve. The mounts where the two screws go are different. How do I replace the new one?
HumboldtRepairMan
#2 Posted : Sunday, August 25, 2013 11:10:18 AM(UTC)
HumboldtRepairMan
If the mount screws don't match up you probably got a wrong replacement part.
Gas Dryer Heat issues after replacing gas valves (Dryer Repair)
by norrisfixgirl 8/11/2013 4:54:55 PM(UTC)
Burner flames too low after replacing gas valve/regulator (Oven Repair (including Ranges and Cooktops))
by tgriz 6/1/2009 5:01:58 PM(UTC)
