JC0123
#1 Posted : Saturday, August 24, 2013 6:09:25 AM(UTC)
JC0123
I had a recent burnout of the upper oven heating element and have replaced the element. The lower oven works properly. After replacing the upper oven element I noticed it will not come on but lower oven still worked properly. I swapped the lower and upper elements and noticed the lower oven still worked (with the new element) but no luck on the upper. Then I have noticed the upper broiler will not come on either. Normally a small light (above the control knob) will come on for the thermostat while heating, it will not come on for the upper oven. I have attached a photo of the control knobs on the oven. Thank you for any input.
JC0123 attached the following image(s):
HumboldtRepairMan
#2 Posted : Saturday, August 24, 2013 8:27:37 AM(UTC)
HumboldtRepairMan
More then likely it's the upper oven thermostat switch and/or bake/broil selector switch.......i'd replace both for safe measure. Check your wiring at the upper thermostat switch and follow the wiring to the upper oven & broil you may have a loose connection or bad wiring. More then likely though it's your switches because it's both bake and broil. You didn't supply a model number so i can't tell you what the part number is. Call Jennair directly if you have a hard time finding the part. Good luck
JC0123
#3 Posted : Saturday, August 24, 2013 9:12:18 AM(UTC)
JC0123
I believe it is Jenn Air model W-210, thanks for your help. The selector swith (in the photo) can be switch to "bake" and the lower oven temperature switch can be turned on and the burner works. No luck with the upper or broil under the same scenario. Thank you again for your response.
