mmckinnon
#1 Posted : Friday, August 23, 2013 8:54:57 AM(UTC)
mmckinnon
Dryer blows cold air, happended gradually.
HumboldtRepairMan
#2 Posted : Friday, August 23, 2013 6:00:41 PM(UTC)
HumboldtRepairMan
First check your venting to make sure you have good venting leaving the house and it's not clogged. Also check to make sure you have 240v going to the unit and flip the breaker on and off a couple times to insure it's not at partial trip...dryers run on (2) 120v circuits one for motion and the other for heat if one side of the breaker is off it may not heat. A good thing would be to disconnect the ducting from the wall while testing.......If it gets hot and stays hot for awhile disconnect from wall it's clogged somewhere and if not here's your parts like and a helpful video to help you diagnose your problem.
Parts for Estate EED4400WQ0 Dryer - AppliancePartsPros.com
Estate is made by Whirlpool this video should help
Whirlpool & Kenmore Dryer Repair - How To Diagnose No Heat - High Temp Fuse 279816 OR 279769 Test - YouTube
