not.a.fan
#1 Posted : 12 years ago
not.a.fan
My Frigidaire Affinity Front Load Washer, will wash, but it will not spin out and drain. I have replaced the Door Lock/Switch Assembly and I have cleaned out the coin trap. After cleaning out the coin trap, I was able to get it to run the spin cycle 1 time. I really do not know what to do next. Any suggestions?
HumboldtRepairMan
#2 Posted : 12 years ago
HumboldtRepairMan
test the voltage at the drain pump everytime you test the drain cycle.......should have 120v. The newer Affinity series both washers and dryers have numerous problems the dryers are even worse. Good luck
