The automatic moisture sensing cycle on my dryer does not work, will not start at all. While it was under contract with Sears I had it checked and they never did get it to work as it should. All of the other cycles work fine.:mad:
My dryer is a Kenmore Model Number 110-68652700.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My dryer is a Kenmore Model 110-68652700
See the attachment for the wiring diagram. The automatic moisture sensing cycle on my dryer does not work, will not start at all. Could you explain more about what is not working when in auto modes. Does the motor start? Do you have heat? Is it just that the timer will not advance? Do you know what sears did to try and get it working? etc.? |
