WildBill5150
#1 Posted : Thursday, August 15, 2013 1:19:15 PM(UTC)
WildBill5150
The oven keeps flashing "Lock Door". I have replaced the Electronic Clock Control with Door Latch but it keeps flashing. I "rebooted" the unit but it still flashes. Any ideas on what it could be? Your help is appreciated!
Thank you!
HumboldtRepairMan
#2 Posted : Thursday, August 15, 2013 3:26:12 PM(UTC)
HumboldtRepairMan
Did you use the self clean function and if so did this happen shortly afterwards? DO NOT USE YOUR SELF CLEANING MODES PEOPLE ALWAYS HAVE PROBLEMS AFTER USING IT. Clean it by hand with easy off.....The excessive tempatures in self cleaning causes damage in most cases.
Try shutting the breaker off for 10 minutes and then test.....There also may be a reset button on the backside of your control panel look for one and resetting it.
Try to run a self clean cycle for 3 minutes then cancel the cycle on it, this should cycle the door lock light off for you..
Here's some helpful links
http://www.fixya.com/support/t2...ile_jtp18_keeps_flashing
http://forum.appliancepartspros...ocked-door-blinking.html
How to Fix Flashing "Locked Door" Light GE Profile Oven - Snapguide
WildBill5150
#3 Posted : Friday, August 16, 2013 9:28:04 AM(UTC)
WildBill5150
Thanks, tried all the fixes but the problem persisted. Found a sensor by the thermostat that was all "gummed" up. Cleaned it really well and it works like a charm now. Thanks to all who sent solutions. It was probably a combination of all.
