Hi
Would appreciate amy help you can offer! I have an Amana AC2228HEKB which has stopped being cold. I have done the following -
1) Removed back and front panel. Vacuumed out. Check compressor and fan was working. 2) Removed cover in back of freezer and checked the fan in their was working. Checked the element in the back of the freezer which was room temperature.
Please can anyone suggest what to check next?
Thanks in advance.
James.
Here are your parts Parts for AC2228HEKB - AppliancePartsPros.comYou will have to choose the correct one from the Matching Model Numbers section. I am assuming that by "element" you mean the evaporator coils (item 1 in section 06 of the parts). Since the compressor is running and there is no frost on the evaporator coils in the freezer you have a sealed system problem. This will be an expensive repair as you need a pro. Often it makes more sense to put the dollars towards a new unit. |
THIS FORUM IS DEAD!!!!!!! |
