Newly installed wall oven dispersed intense heat from 9 vents placed at top of oven door. When opening door, heat noticeably intense on individual trying to remove item from oven. Also noted that entire area above oven door including control panel is so hot that you cannot touch the area without an oven mitt with oven set at 350 degrees. This is a terrible hazard. I have not seen any other oven door with vents on top of the door. There is also the vent above the oven door. Is this a particular flaw. Would not want anyone accidentally touching the oven to get burned.
MHW
