Harleymarli
#1 Posted : Wednesday, August 14, 2013 2:43:18 AM(UTC)
Harleymarli
My Mother board was replaced approx. 2 yrs. ago, it is very hot to touch the seal and where the seal hits the inside of the rerfrigerator!
Could anyone here tell me the cause and if this might be a recall?
It cost me over 500.00 to fix the Motherboard and another part ( that I can't remember) back 2 yrs. ago and I'm hoping this isn't the case again!
Thank You so much for your replies,
Marli
#2 Posted : Wednesday, August 14, 2013 3:16:28 AM(UTC)
Check the condensing fan motor in the back, if not running, put a portable fan on it to cool it down.
Harleymarli
#3 Posted : Wednesday, August 14, 2013 3:39:17 AM(UTC)
Harleymarli
Thank You for your quick response, I will do that but will this just be a temp. fix?
#4 Posted : Wednesday, August 14, 2013 6:33:52 AM(UTC)
If the condensing fan is not turning, you must replace the fan motor. If you have the new motherboard with a lot of relays, it's probably ok, if not you must replace the motherboard also.
