rappy
#1 Posted : Sunday, August 11, 2013 1:40:48 PM(UTC)
rappy
During the self cleaning feature of the top oven I get an "ERR" message (no codes displayed) This repeats itself after about 10 minutes into the cleaning cycle. I tested the lower unit and it works fine. I reset the system by turning off the main power for 5 minutes and reset clock.
HumboldtRepairMan
#2 Posted : Sunday, August 11, 2013 3:57:09 PM(UTC)
HumboldtRepairMan
Avoid using self clean alot of ovens have problems after you use it all brands.....Check your tech sheet behind the touch panel most likely for a list off error codes............err is just error but there should be an f code or something after that.....
