rusty725
#1 Posted : Friday, August 9, 2013 10:00:00 AM(UTC)
rusty725
My washer(whirlpool duet), stopped working. Will turn on and count back to 1 minute before it stops and door stays locked, no water ever enters and washer cycle stays on, "add a garment". ran diagnostic and came up with f20 error code. Replace the Pressure switch and Inlet valve, still does same exact thing. Please help!! Before I buy anymore parts!!:mad: :mad:
HumboldtRepairMan
#2 Posted : Friday, August 9, 2013 4:08:51 PM(UTC)
HumboldtRepairMan
Check your inlet valve screens for mineral or rust........clean the hose from the pressure switch to the tub and make sure that hose doesn't have any leaks....it's best to pull it out and cap one side and blow on the other while under water in the sink.........then take where the hose attached to the base of the tub and clean that out being very careful with a ziptie or something small and bendable metal like a guitar string......make sure also that you are using the right soap if your unit requires HE type soap only use HE and don't use cheap brands either...........DO NOT USE CHEAP HE SOAP!...........NO SUN, PUREX, KIRKLAND FROM COSTCO OR ARM AND HAMMER and avoid using those pouch type pods also i've seen them not breakdown in a unit and clog up in places.............Go to youtube.com and watch the video by mike murphy on how to check out whirlpool duet f20 fix........Good luck
Dishwasher won't run cycles, only fills a bit (Dishwasher Repair)
by Snowfinch 7/7/2015 7:06:10 AM(UTC)
Neptune Washer Won't Run (Washer Repair)
by lacoppari 1/7/2015 7:06:39 AM(UTC)
Stackable washer/dryer- Washer won't run unless dryer is running (Washer Repair)
by abracadabra13 9/2/2013 9:55:12 AM(UTC)
Kitchenaid Dishwasher won't run ? motor (Dishwasher Repair)
by garywool93 8/30/2013 1:23:19 PM(UTC)
Dishwasher won't run (Dishwasher Repair)
by thebling 2/21/2013 9:37:53 AM(UTC)
kenmore washer won't run diagnostic (Washer Repair)
by df_3 9/12/2012 6:12:08 PM(UTC)
Whirlpool GU1500XTLT Dishwasher Won't Run (Dishwasher Repair)
by fishingbear 5/5/2012 8:15:09 AM(UTC)
washer won't run fulid leak out of bottom (Washer Repair)
by jillebean 3/22/2012 11:20:11 AM(UTC)
Dish washer won't run (Dryer Repair)
by rockylowe 3/8/2012 6:50:52 PM(UTC)
Kenmore washer won't run (Washer Repair)
by pjld 1/27/2012 3:11:21 PM(UTC)
Dishwasher Won't Run/Air Dry Light Flashing (Dishwasher Repair)
by Coyote1cf 1/16/2012 10:42:09 AM(UTC)
kenmore front load washer won't run (Washer Repair)
by sahe30 4/24/2011 11:53:04 AM(UTC)
by fredex 2/25/2011 10:05:47 AM(UTC)
KitchenAid dishwasher won't run (Dishwasher Repair)
by johnniered 12/30/2010 9:26:32 AM(UTC)
GE Dishwasher won't run (Dishwasher Repair)
Belarus Logan29 11/21/2010 5:55:12 PM(UTC)
