markopcoltrane
#1 Posted : Friday, August 9, 2013 9:18:48 AM(UTC)
markopcoltrane
Hi
Just moved homes and noticed water will drip into tub slowly when machine not in use...I assume it will be the water inlet valve problem (please confirm) but what perplexes me is that even with the local water mains to the machine closed, it will still drip overnight, then eventually stop after a few inches of water in the tub.
Although it may be coincidence, could the act of moving the machine cause anything that could have broken something internal, and when moving again, any way to prevent this? I have not used this machine for almost 3 years and am using the hoses that I bought new at the time more than 3 years ago, would I have to replace them as well, even though they were not used (stored within the tub in storage).
Thanks,
Marko
HumboldtRepairMan
#2 Posted : Friday, August 9, 2013 4:13:09 PM(UTC)
HumboldtRepairMan
If you have water entering unit whether you have it off or on it's a bad inlet valve.......
