vicrod!2
#1 Posted : Friday, August 9, 2013 8:14:12 AM(UTC)
vicrod!2
burners work, oven door locked and display does not work.:(
#2 Posted : Saturday, August 10, 2013 6:15:35 AM(UTC)
Parts for KESS908 - AppliancePartsPros.com
Choose the correct unit from Matching Model Numbers side panel.
See the attachment for a tech sheet.
Your given model number is short a few digits but it looks like most units in this series are the same. The below is for a PB02.
Looks like the power transformer and some components have a thermal cutoff and a thermal switch in the L1 side of the line so I would start by checking them.
Both should be 0 ohms at room temperature.
If either is open it is a good idea to also check the oven sensor just to be sure that it did not cause an overheating condition.
File Attachment(s):
KESS908.pdf (227kb) downloaded 2 time(s).
Please advise me of a flower delivery service (General Talk)
by Guest 6/30/2024 1:56:13 AM(UTC)
Samsung Refrigerator - Service Kit for Icing Issue (Refrigerator & Freezer Repair)
by keith1386 3/24/2024 8:57:57 AM(UTC)
Compressor Start Device constantly needs replacing (Refrigerator & Freezer Repair)
by norsemen 3/11/2024 2:17:34 PM(UTC)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
stacked washer/dryer service manual (Washer Repair)
by Guest 8/13/2023 1:18:07 AM(UTC)
Refrigerator Repair Services In Dubai (Refrigerator & Freezer Repair)
by superfix appliances 11/14/2021 12:50:05 AM(UTC)
Bosch service/diagnostic mode (Dishwasher Repair)
by earache6 11/9/2021 3:11:16 PM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
Bosch Dishwasher Repair Advice (Dishwasher Repair)
by Donan 9/20/2020 10:03:22 AM(UTC)
Maytag Neptune MAH5500BWW Service Manual (Washer Repair)
by ort11 4/21/2020 9:05:24 AM(UTC)
software testing services india (General Talk)
by thinkinno 5/7/2019 10:32:23 PM(UTC)
Help! Novice needs help! (Washer Repair)
by Amicia007 4/17/2019 3:35:44 PM(UTC)
Maytag Centennail Washer repair advice (Washer Repair)
by rmathieu75 1/6/2019 4:43:14 PM(UTC)
bosch dishwasher only works in customer service mode (Dishwasher Repair)
by doak 11/11/2018 6:46:13 AM(UTC)
