Need help replacing inverter board box (part number W10133449). Can't get plasitc cover off box attached to side of compressor to access plug to connect inverter box. Thanks
Below is from a unit that uses the same compressor so may be applicable. To remove the cover, insert a flat-bladed screwdriver into the top slot, push down on the screwdriver to release the catch, and then rotate the cover away from the compressor at the top, and lift the cover off the bottom catch (see the top right photo Remove the power connector and green ground wire from the compressor terminals. Loosen the strain relief screw and remove the wire. Here is the link to that manual. You will have to join the site in order to download the manual. http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=214 |
THIS FORUM IS DEAD!!!!!!! |
