Lisa Scott
#1 Posted : Thursday, August 8, 2013 5:03:50 PM(UTC)
Lisa Scott
During my last wash cycle there was an unusual sound but not significant to warrant me doing anything. Afterwards the "Rinse Only" light started blinking and won't stop. It won't wash. After the power was turned off then back on we got a code of 1H on the display. When the display went black the "Rinse Only" light started flashing again. Help!! How can I get this thing to work??
#2 Posted : Saturday, August 10, 2013 2:19:22 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
HumboldtRepairMan
#3 Posted : Saturday, August 10, 2013 7:42:08 AM(UTC)
HumboldtRepairMan
Check underneath your unit for any amount of small water leaking near the motor base of the unit........some of these kitchen aids have a small leak problem and it squirts on the components and causes random numerous codes to pop up and it has nothing to do problematic parts but a water leak causing fault codes coming up.
