DFinagin
#1 Posted : Wednesday, August 7, 2013 5:37:49 AM(UTC)
DFinagin
The end of cycle signal does not work on my Roper washing machine. Does anyone have any ideas to fix the problem?
fairbank56
#2 Posted : Wednesday, August 7, 2013 6:36:25 AM(UTC)
fairbank56
Groups: Expert
Did it ever work? I see that this washer has a cycle complete indicator and the specifications say that it does have an end of cycle signal. If it used to work but doesn't now, I would unplug the machine for a couple minutes and plug back in. If that doesn't fix it, tilt the machine back and look for the tech sheet inside the cabinet. Go into service mode and do the calibration function. If that doesn't fix it, you may have a faulty control board. Is it still under warranty?
Eric
DFinagin
#3 Posted : Wednesday, August 7, 2013 7:17:52 AM(UTC)
DFinagin
No it never has worked. All other parts/features work great. I will try the calibration function - thanks.
fairbank56
#4 Posted : Wednesday, August 7, 2013 8:18:38 AM(UTC)
fairbank56
Groups: Expert
Are you talking about the visual indicator lamp or an audible alarm? Maybe it just doesn't have the audible feature if that's what you mean.
Eric
DFinagin
#5 Posted : Wednesday, August 7, 2013 9:34:51 AM(UTC)
DFinagin
I think you are right - only a visual indicator nothing audible.
