:confused:
I have a Thermador Duel Fuel Pro Series Unit, Gas Burners, Electric side-by-side ovens.
I had a power outage and when the power came back on the ovens did not. I shut the breaker for about 20 minutes then turned it back on. The small oven came back on but the big one did not. I have since reset the breaker again but to no avail. One oven comes on but the other one does not.
:confused:
Did you see the oven and the heating lights flashing?
If you did then I need you to post the exact sequence of the flashes beginning with the oven light.
If the range is less then a year old - it should be under the manufacturer warranty and I would recommend to call Thermador for service. This is very complicated model.
