AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool Duet washer will turn itself off - no error message given
I have a Whirlpool Washer WFWW9250WW00 and it will shut off during any cycle. It first will beep then go like it is on pause. If you hit the start/pause button, it will start again then do the same thing and then it shuts it self completely off. No error is given. I have unplugged the washer and left it unplugged for several hours, cleaned the boot and the catch all out and tried it again but the same response. What do you think the problem is?
Try checking the thermister for an ohm reading should have around 16 ohms also inspect the wires from the main board to it make sure you have good contacts also check the drain pump for any clogging.
Washer Repair
