scentsy
#1 Posted : Saturday, August 3, 2013 10:01:48 AM(UTC)
scentsy
My washer stops after washing and wont fill with water when it gets to any rinse cycle. The machine will contine to drain and spin at the end of the rinse cycle but there is no water in it to drain and spin. What could be the problem??
sidfink43
#2 Posted : Sunday, August 4, 2013 5:55:51 PM(UTC)
sidfink43
I don't think you have posted the correct model number as it will not come up on the APP parts page.
If you will check and can repost the right model number we may have some ideas for you.
thanks
Washer stops at rinse cycle (Washer Repair)
by OldJarhead 7/2/2013 3:23:31 PM(UTC)
Problem- Washer stops at rinse cycle (Washer Repair)
by zamana 1/25/2009 3:01:57 PM(UTC)
Washer stops at rinse cycles (Washer Repair)
by Aubriella 12/6/2008 5:58:24 AM(UTC)
Washer stops at Rinse Cycle and doesn't drain water (Washer Repair)
by kukoch 6/2/2008 9:22:18 AM(UTC)
