jimmys3000gt
#1 Posted : Friday, August 2, 2013 1:28:36 PM(UTC)
jimmys3000gt
GE Profile dishwasher only 3 years old (PDWF880R10SS). It would fill with water and then when it comes time to spray the water all over the dishes, nothing would happen. No motor humming sound or anything. When the water spray cycle is over, the water would drain out.
I have swapped out the control module (WD21X10404) but that doesn't fix it. I also swapped out the ESCUTCHEON Bowed Assembly (WD21X10404) but that doens't fix it either. It just continues to fill up with water, then sit there quietly during the spray cycle, and then drains.
Can anyone help me?
scott5495
#2 Posted : Friday, August 2, 2013 2:52:04 PM(UTC)
scott5495
you have two separate pumps on this model. one circulates the water thru the spray arms, and one pumps the water out. the circulation pump must not be running. check to see if you have 120 volts to the motor, if you do, turn power off and see if the motor will turn. turn power back on and if it runs, you have moved the rotor off of a bad spot in the windings. you will have to replace circulation pump. if you do not have 120 to motor, check door switch or look for a bad wire.
