dennisloyola
#1 Posted : Friday, August 2, 2013 4:07:26 AM(UTC)
dennisloyola
Hi - I bought a used KitchenAid electric dryer, I had one before and the heater was not working but the dryer runs, so bought another used on and had the same issue, so got this KitchenAid and faced the same problem.
I then thought it could be my wiring, so checked and as expected there was no power coming to the dryer, so the wiring was lose and so reconnected the wires securely.
Now the dryer keeps blowing the fuse after 2 or 3 runs, have already changed 3 fuses only on the heater side the dryer does run otherwise, just no heat...
So wondering what could be the issue????
