mohawkelly
#1 Posted : Thursday, August 1, 2013 10:12:27 AM(UTC)
mohawkelly
How to enter Factory Test Mode on GE pdwt200v00bb?
scott5495
#2 Posted : Thursday, August 1, 2013 4:09:51 PM(UTC)
scott5495
take the bottom panel off. on the right side there will be a tech sheet stuck between the bottom of the tub and the metal it sits on. this sheet will give you the diagnostics information.
HumboldtRepairMan
#3 Posted : Thursday, August 1, 2013 4:14:32 PM(UTC)
HumboldtRepairMan
Look under the bottom panel for the tech sheet or behind the front panel should be a paper taped inside somewhere that shows you.
kenmore stuck in factory test mode (Washer Repair)
by jadecuir 7/11/2008 8:18:32 AM(UTC)
