darth
#1 Posted : Wednesday, July 31, 2013 1:16:19 PM(UTC)
darth
Our Refrigerator was working fine, and then all of a sudden started to raise temp in the Freezer (+10 degrees F). The Refrigerator was still holding at 40 degrees F.
Checking the compressor lines after reset at first has a very cold outlet, but quickly goes to barely cool. Fan is running strong, but freezer won't pull down any more, and after working on it (requires opening doors a lot) is now at +30 degrees.
Is it low on freon (134) or compressor going bad? No bad noise. Also, evidently new compressor no longer available.:(
darth
#2 Posted : Thursday, August 1, 2013 7:29:39 AM(UTC)
darth
Need compressor no longer available. ( AP3040463
Made by: Whirlpool) Is there any alternative that I can use?
#3 Posted : Thursday, August 1, 2013 8:18:55 AM(UTC)
If no frost on the back freezer panel, you probably have a refrigerant leak/bad compressor.
