After our dishwasher kept getting stuck in the cycle with the pump running continuously, our repairman advised we get a new one because the control board was shot. Instead, we had the board repaired and just installed it. The machine went through the quick wash perfectly, the correct lights were on, etc., etc. Only problem, toward the end of the cycle we had a slow leak coming out the rear of the cabinetry and the machine had a little standing water when the cycle had ended
