My side by side KitchenAid just started making a weird clicking noise. Seems something is trying to turn on but then turns off. Every click on/off cycle lasts for about 30-60 seconds....and it continues non stop.
The ice maker has stopped making ice. Could the two issues be related?
Leading upto this problem, I had noticed that the door area (where the door seal sticks to the frame) used to become very hot. This morning, the door seal area is not hot to touch.
If it helps to diagnose, the ice cream in the freezer is not melting and food is staying cold.
Any advice would be much appreciated.
