Nick M
#1 Posted : Sunday, July 28, 2013 7:33:50 AM(UTC)
Nick M
I purchased a Whirlpool Duet frontloader last month. I really like the machine and have a question concerning the normal operation of the detergent drawer. I recently noticed that when I add detergent before starting the cycle the detergent immediately starts to drain into the tub. I can see the liquid detergent running down the inside of the glass door. Is this normal operation? Thanks in advance for any help.
HumboldtRepairMan
#2 Posted : Sunday, July 28, 2013 9:29:45 AM(UTC)
HumboldtRepairMan
Most detergent dispensors have to fill up to a certain point with water then once it goes over the top of a certain point then it goes into the tub.....if the detergent starts going down immediately as you pour it in doesn't sound right but i could be wrong every once in awhile manufactures do things differently but that doesn't sound right if the water in the top of the dispenser isn't going. May have a crack in the drawer? Pull drawer out and have a quick examination. If no cracks it may just be normal.
Nick M
#3 Posted : Sunday, July 28, 2013 2:00:01 PM(UTC)
Nick M
It did not look right to me either. I only have the washer for about a month but I seem to recall the detergent level staying put. I noticed it yesterday when I put in some softener after putting in the soap. I looked back and the level was low. I thought I had put more in there so I added some thinking I was mistaken and proceeded to watch it drain down. I will try to get in touch with Whirlpool tomorrow and get their opinion.
Nick M
#4 Posted : Monday, July 29, 2013 8:40:14 AM(UTC)
Nick M
After pulling out the drawer as suggested for inspection I observed how the drawer works for powder and liquid detergents. Just had to make sure it was fully seated in the right position.
Guest
#5 Posted : Monday, April 18, 2022 11:42:56 AM(UTC)
Guest
Rank: Guest
United States
I recently just started using this machine and having the same issue. So how to fix it or it's the way the machine operating? If it's normal then it's a bad design because the detergent ran down to the bottom without mixing up with water. I sat in front of the washer the entire the washing cycle and noticed not much soap being used at all. I think I just add the detergent directly into the drum next time then.
