Coverpig
#1 Posted : Friday, July 26, 2013 10:39:50 AM(UTC)
Coverpig
My GE profile oven is displaying a Locked door message. It just started this one day. My husband reset the breaker and we restarted oven and still Locked Door message. Both ovens will not work, just display the message Locked Door. My husband also took apart the electronic display before, so we can fix this, just need to know what part to order and how to replace...
HumboldtRepairMan
#2 Posted : Friday, July 26, 2013 3:39:47 PM(UTC)
HumboldtRepairMan
Check the door lock motor in the back generally it comes up with an f9 error code but maybe yours isn't beeping the code for some reason........every oven goes through a door lock sequence before allowing you to use the oven if it doesn't complete alot of times you can't use it like the problem your talking about......check sears parts website for schematics on your unit to find where it's located
