Mike Adamson
#1 Posted : Thursday, July 25, 2013 8:25:50 AM(UTC)
Mike Adamson
Unit 12-13 years old. Lights go on. No cooling in either r/f. No motor, fan, ice machine sounds for last 24 hours. Guest in my home said it stopped several days ago, restarted on own and then stopped again after a couple days.
I've replaced a capacitor in years past. Minimal handyman skills. Does this sound like something that a novice can fix (like the capacitor / restart module).
Not sure how long this appliance should last.
#2 Posted : Thursday, July 25, 2013 1:03:30 PM(UTC)
Parts for Whirlpool ED25TEXHW00 Refrigerator - AppliancePartsPros.com
Try turning the thermostat up/down a bit to see if it fires up.
If this does nothing it could be that you are stuck in a defrost cycle.
With a flat screwdriver turn the defrost timer (item 6 in the Control Parts section) cam. It will only turn in one direction. Usually there is a hole in the cover that will let you do this without any dis-assembly.
Make sure that the thermostat is not at off.
If it fires up replace the timer.
File Attachment(s):
ED25TE.pdf (175kb) downloaded 15 time(s).
