about a week ago I found this Frigidaire Compact in a ditch seemed to be in good shape brought it home plugged it in and it worked great froze up a 2 liter of pop in about an hour and a half now i got Popsicles melting and warm beer. could the compressor be going bad? please help
Could be about 20 different things but more then likely it's got a bad compressor or coolant leak if you found it in a ditch because those repairs are usually worth more then the fridge is worth. When you plug it in the compressor if it's noisy then gets quiet after a couple minutes that's a sign typically of the compressor going out but you'd need a pressure guage to make sure the return line from condensor to compressor is close to 0 psi. If you plug it in after sitting for awhile and the compressor doesn't make that much of a difference in noise after a couple minutes it may just be a coolant leak, inspect coolant line connections see if you have any oily substance at any of the connections if you do you may have detected the coolant leak. Your best bet is to call an appliance tech with the right tools for this determination.
Is the compressor still running?
You should be able to hear it but also should be able to feel it vibrating.
If it is off then it could be a control thermostat problem.
I cannot find any info on this unit but if it has auto defrost and the compressor is off then it may be a defrost timer problem. |
THIS FORUM IS DEAD!!!!!!! |
