cessmech
#1 Posted : Monday, July 22, 2013 12:46:13 PM(UTC)
cessmech
Door is stuck in closed position.I have removed range top and c/w visual inspection of latch.No defects .Removed door cover and found no defects.Door is stuck in top center.It has not been in the self cleaning operation.NEED HELP
HumboldtRepairMan
#2 Posted : Monday, July 22, 2013 4:45:59 PM(UTC)
HumboldtRepairMan
Usually this will have a code that will pop up when your having problems.......You either have a door latch & lock issue..........a door switch is going bad and keeping the door locked or the main board is fouling out and not releasing the mechanism.
Frigidaire Oven door will not open after self clean (Oven Repair (including Ranges and Cooktops))
by raylegend 11/23/2012 9:30:26 AM(UTC)
Oven door will not open after cleaning cycle (Oven Repair (including Ranges and Cooktops))
by santacruz1966 7/4/2010 11:58:09 AM(UTC)
Viking Oven Door will not Open (Oven Repair (including Ranges and Cooktops))
by bobtex 11/12/2008 6:19:51 AM(UTC)
