nnason
#1 Posted : Sunday, July 21, 2013 3:04:42 PM(UTC)
nnason
My GE True Temp oven keeps shutting off (loses all power - no codes given). It will get up to temp and cook for a while and then shut off. I can tap (or bang sometimes) on the control panel to get it to come back on. I then have to reset the temp and push start again. Sometimes it goes off multiple times, sometimes not at all.
I pulled it out and checked all the connections. There were no loose wires or anything that did not look right.
Any ideas what might cause this?
HumboldtRepairMan
#2 Posted : Sunday, July 21, 2013 7:44:26 PM(UTC)
HumboldtRepairMan
If you can tap on the interface and it resets itself it's either a bad interface or a main board most likely if you say all the wires are clean with no burn marks and well connected.
tyndall00
#3 Posted : Sunday, July 21, 2013 8:01:19 PM(UTC)
tyndall00
Regardless of what you programs or perhaps your location it is important to comprehend the art work associated with backpack providing; this makes a person rucksack more at ease to hold which enable it to assist to ensure that the items necessary initial are certainly not in the bottom!! Simply because you can go with every little thing into the rucksack does not imply tory burch sale you'll want to truly acquire everything in your journey. Should your notion of backpack packing would be to load up your kitchen kitchen sink, at the very least make certain that it's effectively! Never the actual less, it could be a fantastic idea in order to neglect your home sink along with commit some time believing your trip and also operating out there exactly what
you might call for.
Never location everything within your rucksack till you've selected every one of the products you would like to consider. cheap tory burch Lay all the desired valuables in your backpack in the crystal clear space and also examination when they are crucial or maybe if they are far more from your 'wish list' school. Your artwork of rucksack packaging includes being aware of what to bring along. Naturally, waterproofs give up garments, meals and also snack foods are usually quite critical -- guides for late night researching, you'll more than likely by no means wide open because you will become exhausted coming from stimulating oxygen and also collapse contentedly directly into mattress with out opening tips, tips which may have taken up valuable room plus always be heavy to carry. Though your backpack appears large inside shop, the moment house you will recognize that that quickly fills up -- which means significance associated with successful rucksack providing.To grasp the particular art work associated with rucksack providing you never demand a diploma or degree, but a specific mind and a lot of common feeling can get you via. Place the biggest components of the lower - you need to maintain a great heart involving equilibrium.
MD10962
#4 Posted : Friday, October 3, 2014 7:42:03 AM(UTC)
MD10962
Shortly after the stove top was working this morning, the entire stove, oven and dashboard stopped working. It seems the power is off yet nothing elcectrical changed within the kitchen area. I gather this might need repairing. Thoughts? an easy fix for a repairman?
