gregorygbaker@yahoo.com
#1 Posted : Wednesday, October 7, 2009 6:08:33 PM(UTC)
Last week wasn't getting any water flow from water dispenser so i replaced it with new water filter. Then i had water flow. Now this week there is no water flow at all. And i was wondering could it be the water flow pump in this particular model that needs replacing.
applianceman
#2 Posted : Thursday, October 8, 2009 10:58:48 AM(UTC)
applianceman
Often on this model the water line will freeze in the freezer door. Remove the coupling from the bottom of the freezer door and see if you get water there when you attempt to use the water dispenser. If water does come once you disconnect the coupling the line is frozen. To fix this open the door and press the door switch. Then repeatedly press the dispenser lever until you get water.
IF you don’t get water when you take the coupling loose the valve may be your problem.
This page may help
GE Refrigerators Repair Guide
