Pat3339333
#1 Posted : Wednesday, July 17, 2013 11:26:14 AM(UTC)
Pat3339333
Hi. Just moved this fridge to a new house. Plugged it in, the compressor kicked on, but after 24 hrs, its not cooling at all (but there's still fan and/or compressor sounds).
This model had electronic controls and I adjusted them to a middle setting.
The fridge worked before moving and remained uptight during the move.
I have but yet ibstalled the water line.
Any thoughts for fixing this?
Thanks.
#2 Posted : Thursday, July 18, 2013 3:36:36 AM(UTC)
Check to be sure that the compressor is running. You can usually hear it but also should be able to feel it vibrating.
If is is on remover the cover in the freezer so you can inspect the evaporator coils. If there is no frost or just frost in one area then you have a sealed system problem.
This will be an expensive repair as you need a pro.
Often it makes more sense to put the dollars towards a new unit.
Note be sure that the compressor has run continuously for at least an hour. If you do this check shortly after or during a defrost cycle you may end up with the wrong diagnosis.
