TMuzzio
#1 Posted : Wednesday, October 7, 2009 5:14:20 PM(UTC)
TMuzzio
I have a GE Monogram stove, Model ZGU660 ES3BG. When we turn on one of the burners, the igniters will often keep clicking. One burner might work correctly for several days while the others will continue to click. A few days later, the pattern will change. Perhaps two or three burners will work correctly while the remaining ones will cause the clicking. There appears to be no consistent pattern. I have read the blogs on this issue and have a couple of questions.
    <LI style="MARGIN-BOTTOM: 10pt">Some blogs say it’s the igniters. Other blogs say it’s the burner caps. How do I determine which it is?
  • The response to a similar question on this site says it’s the igniter, and that the igniter is on the right front burner. On my stove (same model), each burner has an igniter. If this is an igniter problem, do I need to replace each igniter?
Thank you for your assistance.
