I have a Frigidaire wall oven model GLEB27S7ASA and went to push bake to cook something. After pushing bake, the thermostat goes from 350 to nothing in seconds and doesn't offer the opportunity to increase or decrease heating. The up and down arrows seem to do nothing. Same with the timer and broil functions. I can run a clean cycle, but can not change its timer. It does heat up when on a clean. Is this a control panel issue? Is there a place to get a new one and try to replace it and if that isn't the problem, it can be returned? Also, what does everyone do with their parts that are replaced, I would like to recycle and find someone who might be able to fix old motors and such and give new life to them. Thanks
THIS FORUM IS DEAD!!!!!!! |
