Abrim
#1 Posted : Sunday, July 7, 2013 5:35:35 AM(UTC)
Abrim
Hello
My maytag Gemini double oven wont reach temp
Keeps beeping. F1-2 f1-3 f3-2 error codes
We replace top and bottom sensors. Yet still no repaired
Please assist
Much love
Amy
scott5495
#2 Posted : Sunday, July 7, 2013 7:44:42 AM(UTC)
scott5495
amy, check the wires from the sensors to the control to make sure there is no damage. since the codes are indicating lower and upper oven sensors, I suspect there is a problem with the control. if you have an volt ohm meter, the sensors should read about 1000 to 1100 ohms. check the control board where the sensors plug onto. may be a broken solder joint. if it is you may resolder. good luck
erricwillson
#3 Posted : Tuesday, July 30, 2013 12:12:23 AM(UTC)
erricwillson
Two months ago i was also facing this problem. I try all the thing and it satrt working after few days problems persist then i came to know one of its transistor showing problem.
Maytag double oven
