lnorri
#1 Posted : Friday, July 5, 2013 7:50:45 PM(UTC)
lnorri
Stove was used this morning. Try to turn it on this evening and nothing. No light or anything. Check all circuit breakers that's OK (Help)
#2 Posted : Saturday, July 6, 2013 1:55:39 AM(UTC)
I cannot find any info on the given model number.
Since the total unit is dead odds are that it is a power problem so I would start by checking it.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
