Web71
#1 Posted : Friday, July 5, 2013 4:08:24 PM(UTC)
Web71
Hi. The exterior lights on my fridge are all out (the indicator LEDs and the appliance bulb). The refrigerator and ice maker/water dispenser are all working fine - just the exterior lights are out. I just changed my water filter and mistakenly held the LOCK/UNLOCK and AUTO LIGHT buttons instead of the LOCK/UNLOCK and WATER button to reset the filter indicator LED. I'm guessing I blew a fuse but have no idea where to look OR simply turned off the lights and can't figure out how to turn them back on. Like I mentioned at the beginning, the fridge and accessories are all operating fine so not a high priority - just curious if it's something easy. -- JC
OOPS- nevermind. Apparently holding LOCK/UNLOCK and AUTO LIGHT toggles between off and on for all exterior lights. Just held them again and everything is back on and working.
#2 Posted : Saturday, July 6, 2013 4:56:18 AM(UTC)
Glad to hear you figured it out.
FYI. If in the future you run into any appliance etc. which uses an electronic board and it hangs up or start doing weird things, try unplugging it for a couple minutes. This should reset the board back to the factory defaults.
