Washer runs fine in all cycles except rinse cycle, then just hums. When timer knob is manually turned to spin, it completes the wash cycle. I suspect a bad timer, but before laying out $$$ want to make sure. Thanks!
Groups: Expert
Where in the cycle does it stop? Where is the hum? timer, drive motor, fill valves?
Wash- fill, agitate, drain, spin Rinse- fill, agitate, drain, spin
Eric
