First, I apologize for the model number. Part is worn off and its not listed on the manual. The ?? might be 58. About a year ago, I was moving things in the garage and something hit the dryer. Since then, it will intermittently only dry for 1-2 minutes and then turn off. All the lights blink too. After unplugging for a while or restarting several times, it usually went back to normal. I did a bunch of trouble shooting and it came up with the stuck button code, which I'm pretty sure was not true. The other night, I was doing laundry and it started acting up again. I banged the top in frustration and now the dryer will not stop tumbling unless it is unplugged or if the door is completely open. No heat, just tumbling. From reading many similar issues, it seems the control panel needs replaced. Just checking that this seems to be the issue. Also, it seems pretty simple to replace. Any tricky spots? Thanks!
