Hello,
My dryer does not heat up, It will run thru it cycle( any setting) and buzzer goes off and stop but no heat. I checked the fuse in the back and its good checked the ohms on the igniter and nothing I replaced the Igniter. It lights up but no flame! now what do i do? Any suggestions?
Thank you.
I changed the the gas valves and it works fine.
