chris smith
#1 Posted : Thursday, June 27, 2013 3:54:40 AM(UTC)
chris smith
Help!I have a cabrio washer M# wtw5550xw2 1.5 yrs old and has started shutting down in spin cycle. At first i could turn it to drain and spin cycle and it would spin now it shuts down in that cycle also. I found the service maual and did some tests. Spin cycle shuts down in the auto mode, but spins normally in the manual test mode. You can hear erractic shifting just before it shuts down. It does not matter if you have 1 shirt or 5 sweaters in the basket. Thinking main control board or shifter?
cin567
#2 Posted : Saturday, June 29, 2013 12:28:29 PM(UTC)
cin567
On 5-24-2011 Silverfz1 posted a fix for drain issues in Cabrio washers. Multiple people said it worked for them as well. Here is the link to that post, or you might have to search this forum for silverfz1
http://forum.appliancepartspros...ong-drain-problem-2.html
chris smith
#3 Posted : Monday, July 15, 2013 3:38:09 AM(UTC)
chris smith
Update replacing the shifter has fixed the problem. My cost $53.00.:)
