David R. Parker
#1 Posted : Tuesday, June 25, 2013 3:17:37 PM(UTC)
David R. Parker
Both ovens make a bad fan noise whether they are in convection or not. I assume it is the cooling fans on each oven. Can I please get some help on this?
oloneal
#2 Posted : Sunday, September 29, 2013 1:03:26 PM(UTC)
oloneal
I am having a similar issue; also on a KitchenAid double-oven range (Mdl KERS505XWH). When the fan kicks on, it has a loud buzzing noise which then moderates within a few seconds to a normal level. This is a little irritating, but may be normal as far as I know. Any comments?
