gregaguilar
#1 Posted : Monday, June 24, 2013 8:22:42 AM(UTC)
gregaguilar
this kenmore elect dyer model 110.87081601 wont do nothing have checked thermo cut off i am gettinh 220 to machine door switch okay what is next?
#2 Posted : Wednesday, June 26, 2013 1:05:44 AM(UTC)
Parts for Kenmore Dryer 11087081601 - AppliancePartsPros.com
See the attachment for the tech sheet
[COLOR="Blue"]i am gettinh 220 to machine door switch okay what is next?[/COLOR]
Where atr you measuring?
You should not see 220 at the door switch.
It should be 120 volts if uoy are using ground/Neutral as the reference.
Does the drum light work?
Have you checked for 120 volts from Neutral to L1 and to L2?
File Attachment(s):
87081601.pdf (602kb) downloaded 1 time(s).
gregaguilar
#3 Posted : Wednesday, June 26, 2013 4:17:51 AM(UTC)
gregaguilar
Originally Posted by: denman Go to Quoted Post
i am not getting 220 to door switch i said to unit 120 on each leg and 220 across both legs belt switch okay thermo okay it is either the ui power bard, the circuiet board or the houe electronics assembly according to the tech sheet they tell you to replace on if no good replace the other and last if no good replace the last board what is this??????
