the 2 front outlets on my kitchenaid stove have no power. Problem first started on the lrft side, the right side had power for a while. Now they are both with no power All stove functions are working and the breakers haven't tripped. What would cause this problem?
I cannot find any tech info on the given model number. Please check it.
[COLOR="Blue"] All stove functions are working and the breakers haven't tripped.[/COLOR] I am assuming that you mean the house wiring breakers.
[COLOR="Blue"]What would cause this problem?[/COLOR] The 115 volt outlets are usually fused so perhaps that has blown. Some units use a small circuit breaker that can be reset. Perhaps whatever you are plugging into them is pulling more than 15 amps. |
THIS FORUM IS DEAD!!!!!!! |
