I am having a problem with my dryer - There is no heat.
The dryer is a Kenmore Elite HE3 Limited Edition - Model # 110-C83902201
Could it be something as simple as the fuse?
If so - where is(are) the fuse(s) located and how do you test and replace a burnt out fuse?
Please help
Hi, it could be a fuse. The fuse is located on the element housing. It is the fuse furthest back on the housing. It should have continuity. You want to test it with the unit unplugged and one wire of the fuse. The element is probably the most common issue on these units. The element should have continuity as well.
