My LG DLE Dryer just quit coming on. Drum light comes on but nothing happens when I push the start button. Can't find anyone to work on these machines.
Sorry but I cannot not find ant tech info on the given model number so the following is just guesses.
The unit may have a belt switch so check that the belt is OK. Check that the door switch actually closes. Check that the push to start switch (if it uses one) actually closes. Many units has a thermal fuse that kills power to the motor. |
THIS FORUM IS DEAD!!!!!!! |
