I've just received the replacement pump for Amana washer NFW7200TW, part number 34001340. The mount is different than the old one, there are no screw holes to attach to the metal plate that the old one was attached to. I've seen reference on this forum to the technical bulletin which explains installation, TDL-0106-B.pdf, but cannot find this on the web.
I had the same problem so I used the old housing with the mount. It still didn't solve my problem however. My washer will still not pump.
