lmbuchholz
#1 Posted : Wednesday, June 12, 2013 10:32:06 AM(UTC)
lmbuchholz
I have a GE dishwasher that continues to beep and the "normal wash" light would flash until it was reset. We were able to reset the dishwasher and stop the beeping a few times after the complete wash cycle finished. 2 days ago we ran the dishwasher and it will no longer reset. The only way to stop the beeping is to open the door. The normal wash light continues to flash. Any suggestions? I've read several other similar threads and it seems to either be the control asn or the escutcheon. Not sure which to order...
thanks!
Simon / APP Team
#2 Posted : Wednesday, June 12, 2013 12:37:39 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it is a bad control board
Part number: WD21X10265
Before replacing it , check first the door interlock switch (with latch closed BW-BX and WX-WR should be closed).
Here are the breakdown diagrams and Escutcheon & Door Assembly parts for GE GSD4000N10WW - AppliancePartsPros.com
Post the results.
Simon.
